Thanks for the answer. I remembered somethink like this. But this still doesn’t explain the difference in CU value. Or am I missing something?
Farming reward verification tool
The CU value is linked to the entry you make in the calculator. If you put in your original values (320GB ram, 40 threads and 4000GB of SSD) it returns 79.75 CU.
But if you enter the values in Base24 (so 314.828GB ram, 40 threads and 3726.023GB of SSD) it returns the CU value of 74.52 which is exactly as it is in the tool where you see the payment info.
So I think this is correct?
are there plans to automate this process for each farmer into some kind of a usable monitoring dashboard? This process would be clunky for one node, but for any farmer who has more than one node running…this would be an impossibly time-consuming task.
I believe there are on-going discussions to implement the tool within the Explorer dashboard (or something similar on those grounds), however, I can’t just confirm yet if it is an automated approach. We’ll be certain to update the community when we have more information on the subject.
Check out this thread, where you can provide input on the new tool: Community Feedback on Minting Overview Tool
