Hey @LongStreetTech, this is @sigzag here… have two accounts. So please don’t wonder
That’s weird! Both nodes have the same capacity. There are 8x 800GB SSDs installed. RAID-Controller is set to HBA-mode so drives are attached bare-metal like it’s supposed to be.
Just checked storage health on those servers. Everything is fine. Also there is literly no utilization on them.
I guess ZOS should be able to split a virtual drive (exeeding the size of a singel SSD) over multiple physical drives. So. I have no idea what causes the error you are running in. I think that should be investigated by dev-team.
I could give you another node ID where a single 4TB ssd is installed (same other hardware specs) if you wandt to try again. Maybe that works out. let me know!
