Hi @Dany,
All looks good!
➜ terraform-dany git:(main) ✗ ssh root@178.250.167.69
ssh: connect to host 178.250.167.69 port 22: Connection refused
➜ terraform-dany git:(main) ✗ ping 178.250.167.69
PING 178.250.167.69 (178.250.167.69) 56(84) bytes of data.
64 bytes from 178.250.167.69: icmp_seq=1 ttl=51 time=135 ms
64 bytes from 178.250.167.69: icmp_seq=2 ttl=51 time=126 ms
64 bytes from 178.250.167.69: icmp_seq=3 ttl=51 time=137 ms
64 bytes from 178.250.167.69: icmp_seq=4 ttl=51 time=120 ms
64 bytes from 178.250.167.69: icmp_seq=5 ttl=51 time=128 ms
^C
--- 178.250.167.69 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4002ms
rtt min/avg/max/mdev = 119.557/129.110/136.627/6.248 ms
The authenticity of host '178.250.167.69 (178.250.167.69)' can't be established.
ED25519 key fingerprint is SHA256:GZduV+dbPnaRHqRwNzoO1JRVXS5eH+E7ZKeTcfzLrX8.
This host key is known by the following other names/addresses:
~/.ssh/known_hosts:33: 301:d12e:3351:4208:c32b:a725:4b6c:aa03
~/.ssh/known_hosts:35: 301:d12e:3351:4208:9a7c:cf44:d2d4:f788
~/.ssh/known_hosts:36: 301:d12e:3351:4208:6243:5c48:b899:8932
~/.ssh/known_hosts:37: 301:5393:bfab:9bfd:35f:140b:5736:7042
Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
Warning: Permanently added '178.250.167.69' (ED25519) to the list of known hosts.
Welcome to Ubuntu 20.04.4 LTS (GNU/Linux 5.12.9 x86_64)
* Documentation: https://help.ubuntu.com
* Management: https://landscape.canonical.com
* Support: https://ubuntu.com/advantage
This system has been minimized by removing packages and content that are
not required on a system that users do not log into.
To restore this content, you can run the 'unminimize' command.
The programs included with the Ubuntu system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Ubuntu comes with ABSOLUTELY NO WARRANTY, to the extent permitted by
applicable law.
root@proxy1:~#
Congratulations! The connection refused in the beginning is because this flist start a few daemons and this takes some time. Last step in theprocess is to start sshd As you can see, it got there and works.
Let’s cable the other nodes as well
