requirements
- install Caprover = your app environment
install
Go to the apps section choose appsmith, make sure you choose the one with DB inside.
you should see:
now configure
Go to your apps click on the link of appsmith
you should see welcome page and after it:
incredibly powerful
I made a new app in minutes
Just used the example embedded database and it worked, magic.
