Hello all, looking for some help when I am installing zero-os on my pc its seem to get to the final stage of install then go blank? any ideas
Blank Screen OS
Hey @brettlambourne,
Seems your post got flagged for moderation because the “o” was missing from “hello”
The first thing I’d check is if your node shows online at explorer.grid.tf. It’s possible that there is just an issue with the display but the node is actually working. In that case, I’d just disconnect the display and not worry about it.
If that’s not the case, could you share a photo of the last thing you see on screen before it goes blank?
