Buying SPORES: A simple guide
How to buy SPORES with your TFT
Follow these three steps to get your wallet ready and buy SPORES.
Step 1: Make sure your TFT are on TFChain
Your TFT need to be on TFChain before you can use them to buy SPORES.
If your TFT are on Stellar, open the Bridge in your wallet app:
  1. Select Stellar as the source and TFChain as the destination.
  2. Enter your receiving TFChain wallet address in the To field.
  3. Enter the amount you want to bridge.
  4. Check the details and transfer fee, then click Submit.
Seeing “Address must have a twin ID”?
A twin ID is your blockchain identity on the ThreeFold Grid. Some older wallets may not have one yet.
To add a twin ID to your wallet:
  1. Open your wallet in the app and tap Info in the bottom-right corner.
  2. Under Secrets, copy your TFChain secret.
  3. Go to dashboard.grid.tf and log in using that secret.
Logging in will automatically create a twin ID for your wallet. You can then return to the app and try the bridge transfer again.
Step 2: Log in to the migration portal
Once your TFT are in your TFChain wallet:
  1. Go to migrate.projectmycelium.com.
  2. Click Login.
  3. Enter your TFChain mnemonic (secret phrase) for the wallet holding your TFT.
After logging in, you will see the TFT balance associated with that wallet.
Keep your secret phrase private. It gives access to your wallet. Check the website address carefully before entering it, and never share it in messages or screenshots.
Step 3: Buy SPORES
Click Buy SPORE and follow the on-screen instructions to complete your purchase. Review the purchase details before confirming.
The deadline to buy SPORES at a discount rate (1 TFT = 10 SPORE) is being extended until the end of the year to make sure we are ready for the Marketplace launch and to give people enough time to convert at this rate.
Thanks! I did check my wallet in my threefold connect app and saw the TFT’s were on Stellar and not TFchain. Now I changed that, so my TFT’s are now in my connectapp in the TF chain.
Though what I found strange, I did already have my TFT’ s visible in my migration portal and changed them already to Spores. I don’t quit understand why, but I think now my migrationportal is uptodate and ready for migration, because I do see my farm, my node and my TFT and Spore balance in migtation portal. Sounds this ok?
Hey @remko! Yes, that sounds correct. If your farm, node, TFT, and SPORE balances are all visible in the Migration Portal , then it looks like everything is properly synced and you should be ready to proceed with the migration if you haven’t done it yet.
