Checking uptime/stats after Titan v3 migration
Last month, I made two changes to my threefold setup: On the first day of Feburary, I set up a DIY node. Then on the 10th I migrated my Titan from v2 to v3.
The Titan is now listed in the Threefold Connect app in “Farms on v3”. I can see its Farm ID and Node ID. The DIY farm I made is listed in “Other v3 farms”. I can easily view details for the DIY farm at the TFchain Portal (portal.grid.tf). I used to see details on the Titan by going to explorer.threefold.io/all and pasting its address into the provided text box, but that doesn’t work anymore (even if I explicitly set Grid V3 in the Grid Version dropdown).
I’m not exactly clear on how I can get details for the Titan now. What’s the SOP to get there? Is there a way to import the Titan’s node into my account on the TFchain Portal, or do I need to go about it in an entirely different manner?
Considering you already have migrated from V2 > 3, you should now be able to see the status of your node in V3 Explorer - https://explorerv3.grid.tf .
You can narrow down your search using your Farm ID in the nodes explorer - https://explorerv3.grid.tf/nodes
If you require additional assistance to understand how to navigate there, please connect with us via our live chat. You can find that on threefold.io or your ThreeFold Connect app.
Thanks, this was really helpful. I can now see details and uptime of my first farm in explorerv3.grid.tf. Is there a tutorial anywhere for adding the farm to my account on the Tfchain Portal, so all my nodes appear in the same place? I tried the Create Farm button, but it just created a blank farm without giving any sort of options.
I’ll have to scour the library for a while today to get a bit of a better idea about how all of this comes together.
These guidelines will be helpful: Creating a Farm / Farm ID - Zero-OS v3
Additionally this will help too: Here is the procedure you can follow to get on Grid 3 - You need to register yourself on the TFChain, create a farm and, with the farm ID, create a bootstrap image from https://v3.bootstrap.grid.tf/ on USB. Start from creating a Farm here - https://library.threefold.me/info/manual/#/manual__create_farm
