Dear Friends,
This post is intended for friends at Matic
. Both ThreeFold and Matic share common values and there is an enormous potential that can be exploited together, especially when it comes to leveraging ThreeFoldβs peer to peer cloud network.
We will quickly demonstrate how to setup a Matic node on the ThreeFold Grid . The purpose here is to get people started. The configuration can be tweaked to perfection with other experts in the community.
What we will do ?
- Setup your 3bot
- Log in and create your Network
- Get your wallet loaded
- Deploy your Matic container
- Access your Matic container
- Verify your Matic deployment
Before you start, we have 2 networks publicly available
- Mainnet @ https://explorer.grid.tf
- Testnet @ https://explorer.testnet.grid.tf
Step 1 - Setup your 3bot
The 3bot has a virtual admin that gives you access to the ThreeFold Grid for your deployments (containers, virtual machines, S3 storage and so on). The manual provides detailed instructions on how to set up your 3bot.
If this part is done, rest should be extremely easy as management is done via web interface.
To access the virtual admin interface, in your browser use the following link,
http://YOUR_IP_HERE/admin
Step 2 - Log in and Create your Network for Deployment
From the previous step, http://YOUR_IP_HERE/admin
Log in here with your 3bot. Make sure you open the ThreeFold connect app first!
Once you log in, Go to Solutions and then go to Network . The interface is user-friendly and it should be easy. Few things to note,
- Use IPv4 network unless you are sure you have IPv6. You can test IPv6 connectivity here
- It is better to have the chat bot configure the network for you unless you have specific requirements
- The βAdd Accessβ option is to add a grid node to be a part your network.
Note : The wizard will ask you to download your Wireguard configuration. This is important as you wonβt be able to access your network without it. This serves as an entry point to your private network.
Step 3 : Get your wallet loaded with TFTs -
Buying TFTs should be simple. We suggest you to follow this link
You can load your wallet from the ThreeFold Connect App, create a new wallet or import an existing wallet to your 3bot admin. It is a totally a matter of choice. We recommend that you use the wallet ThreeFold Connect App.
You also have the option to create testnet funded wallet in case you are deploying on testnet.
Step 4 - Create your Matic Container - Time to Rockβn Roll
Under Solutions , go to Generic Container , the wizard will guide you accordingly.
- Select the network name which you created . Your container is going to be deployed in this network.
- Enter the container name, size in terms of CPU and memory . Ideally start with 2 CPUs and 2048 MB memory, since this is a full node.
- The flist link you have to use is => https://hub.grid.tf/arehman/v2-matic-1-3.flist
- Would you like access to your container through the web browser (coreX)? Select NO . You may want to use this for troubleshooting.
- Set the IP address from the drop down list you want to assign to your container.
- The container entry_point should be set to
/start_matic.sh. - Under environment variables , use pub_key=your_public_key_here . This would allow to SSH into the container once it is deployed. NOTE : This should be an ed25519 public key. You can also log into the container with the default password with root user, βtfnow2020β
- You can skip the option to push container logs or set it to NO.
Define your machine size,
In case you want to attach a separate volume for persistence, make sure the mount point is set to /matic-data
Please ensure to select the appropriate capacity pool for your deployment. To know about capacity pools, follow this link
Set the environment variables which should be the public ssh key,
If all goes well, you would be asked to pay through a QR code or choose from the wallets in the 3bot Admin.
Step 5 - Access your Matic Container
To access the container,
For Linux , wg-quick up path_to_wireguard_conf_file. For example, wg-quick up /my-wg/net-1.conf
For windows , Import the downloaded wireguard configuration from Step 2,
Once the wireguard tunnel is up, you can test connectivity by doing a ping test for your container IP address. Access the container with ssh using your private key.
ssh -i path_to_your_privatekey root@container_ip_address, For example ssh -i /opt/mysshkey root@172.20.10.5
The SSH public key should be provisioned during the container deployment.
NOTE : You can also log into the container with the default password with root user, "tfnow2020"
Please ensure to secure the container with your own settings.
Step 6 - Verify your Matic node Deployment
Once you have deployed, now go to Solutions and click "My Workloads",
You can click the container name here to see details, Here is a view of it,
Once you log in, you should see the screen below,
Inside the container, do a ps -ef , you should see the matic daemon / bor running,
root@zero-os:~# ps -ef
UID PID PPID C STIME TTY TIME CMD
root 1 0 0 10:01 ? 00:00:00 /usr/sbin/sshd -D
rabbitmq 249 1 0 10:01 ? 00:00:00 /usr/lib/erlang/erts-10.2.4/bin/epmd -daemon
root 2167 1 99 10:02 ? 11:13:15 heimdalld start --home /matic-data/heimdalld
root 2176 1 0 10:02 ? 00:00:53 heimdalld rest-server --home /matic-data/heimdalld
root 2476 1 11 10:02 ? 01:02:50 /go/bin/bor --datadir /matic-data/bor/data --port 30303 --http --http.addr 0.0.0.0 --http.vhosts * --http.corsdomain * --http.port 8545 --ipc
root 2668 1 0 10:02 ? 00:00:00 sshd: root@pts/0
root 2672 2668 0 10:02 pts/0 00:00:00 -bash
root 2755 2672 0 19:08 pts/0 00:00:00 ps -ef
You should be able to see bor and heimdalld processes running,
root@zero-os:~# netstat -lntpe
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
tcp 0 0 127.0.0.1:26657 0.0.0.0:* LISTEN 0 288525351 2167/heimdalld
tcp 0 0 127.0.0.1:6060 0.0.0.0:* LISTEN 0 288508446 2167/heimdalld
tcp 0 0 0.0.0.0:4369 0.0.0.0:* LISTEN 103 288521231 -
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 288467733 1/sshd
tcp6 0 0 :::30303 :::* LISTEN 0 288526410 2476/bor
tcp6 0 0 :::7071 :::* LISTEN 0 288495389 2476/bor
tcp6 0 0 :::26656 :::* LISTEN 0 288525355 2167/heimdalld
tcp6 0 0 :::8545 :::* LISTEN 0 288526417 2476/bor
tcp6 0 0 :::26660 :::* LISTEN 0 288506630 2167/heimdalld
tcp6 0 0 :::1317 :::* LISTEN 0 288508441 2176/heimdalld
tcp6 0 0 :::4369 :::* LISTEN 103 288521232 -
tcp6 0 0 :::22 :::* LISTEN 0 288467735 1/sshd
The data directory is /matic-data. If you attach a persistent volume to the container, this should serve as the mount point to it.
root@zero-os:/matic-data# tree -dh
βββ [ 8] bor
β βββ [ 22] data
β βββ [ 146] bor
β β βββ [ 14] DATA_DIR
β β βββ [1.1K] chaindata
β β β βββ [ 390] ancient
β β βββ [ 78] lightchaindata
β β βββ [ 98] nodes
β β βββ [ 44] triecache
β βββ [ 0] keystore
βββ [ 28] heimdalld
βββ [ 200] config
βββ [ 164] data
β βββ [1.0K] application.db
β βββ [ 13K] blockstore.db
β βββ [ 78] evidence.db
β βββ [ 438] state.db
β βββ [ 138] tx_index.db
βββ [ 116] logs
19 directories
If you do, tail -f /matic-data/heimdalld/logs/heimdalld.log, you will logs for data sync,
root@zero-os:/matic-data# tail -f /matic-data/heimdalld/logs/heimdalld.log
I[2020-12-29|19:12:36.990] Committed state module=state height=510074 txs=0 appHash=230795A8692340331D652FA390AAE52996C9B97D01F1A7B83CD2918F7624EE75
I[2020-12-29|19:12:36.996] Executed block module=state height=510075 validTxs=0 invalidTxs=0
I[2020-12-29|19:12:37.070] Committed state module=state height=510075 txs=0 appHash=230795A8692340331D652FA390AAE52996C9B97D01F1A7B83CD2918F7624EE75
I[2020-12-29|19:12:37.076] Executed block module=state height=510076 validTxs=0 invalidTxs=0
I[2020-12-29|19:12:37.149] Committed state module=state height=510076 txs=0 appHash=230795A8692340331D652FA390AAE52996C9B97D01F1A7B83CD2918F7624EE75
I[2020-12-29|19:12:37.155] Executed block module=state height=510077 validTxs=0 invalidTxs=0
I[2020-12-29|19:12:37.274] Committed state module=state height=510077 txs=0 appHash=230795A8692340331D652FA390AAE52996C9B97D01F1A7B83CD2918F7624EE75
I[2020-12-29|19:12:37.283] Executed block module=state height=510078 validTxs=0 invalidTxs=0
I[2020-12-29|19:12:37.402] Committed state module=state height=510078 txs=0 appHash=230795A8692340331D652FA390AAE52996C9B97D01F1A7B83CD2918F7624EE75
I[2020-12-29|19:12:37.407] Executed block module=state height=510079 validTxs=0 invalidTxs=0
I[2020-12-29|19:12:37.527] Committed state module=state height=510079 txs=0 appHash=230795A8692340331D652FA390AAE52996C9B97D01F1A7B83CD2918F7624EE75
I[2020-12-29|19:12:37.532] Executed block module=state height=510080 validTxs=0 invalidTxs=0
I[2020-12-29|19:12:37.607] Committed state module=state height=510080 txs=0 appHash=230795A8692340331D652FA390AAE52996C9B97D01F1A7B83CD2918F7624EE75
I[2020-12-29|19:12:37.613] Executed block module=state height=510081 validTxs=0 invalidTxs=0
I[2020-12-29|19:12:37.686] Committed state module=state height=510081 txs=0 appHash=230795A8692340331D652FA390AAE52996C9B97D01F1A7B83CD2918F7624EE75
I[2020-12-29|19:12:37.692] Executed block module=state height=510082 validTxs=0 invalidTxs=0
I[2020-12-29|19:12:37.765] Committed state module=state height=510082 txs=0 appHash=230795A8692340331D652FA390AAE52996C9B97D01F1A7B83CD2918F7624EE75
I[2020-12-29|19:12:37.774] Executed block module=state height=510083 validTxs=0 invalidTxs=0
That should be pretty much !
. We have a matic full node running. Once the node syncs, you can update keys / wallets as per your requirements. This should get you started !
Sources
