Idea
- easy way & fast to get my development machine with
- codeserver = editor
- vlang
- nodejs
- I connect over planetary network to do my work, which is awesome
- I was doing all of this with Gitpod, but now I am using this
terraform {
required_providers {
grid = {
source = "threefoldtech/grid"
provider "grid" {
mnemonics = "THIS YOU NEED TO FILL IN"
network = "test" # or test to use testnet
resource "grid_network" "net1" {
nodes = [1]
ip_range = "10.1.0.0/16"
name = "kds_network"
description = "newer network"
add_wg_access = true
resource "grid_deployment" "d1" {
node = 1
network_name = grid_network.net1.name
ip_range = lookup(grid_network.net1.nodes_ip_range, 1, "")
disks {
name = "root"
size = 10
description = "root vol"
vms {
name = "vm1"
# flist = "https://hub.grid.tf/samehabouelsaad.3bot/abouelsaad-grid3_ubuntu20.04-latest.flist"
flist = "https://hub.grid.tf/omarabdul3ziz.3bot/omarabdul3ziz-ubuntu-20.04-devenv.flist"
# entrypoint = "/init.sh"
entrypoint = "/start.sh"
mounts {
disk_name = "root"
mount_point = "/root"
cpu = 4
memory = 1024
# rootfs_size = 10000
env_vars = {
SSH_KEY ="ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQC/9RNGKRjHvViunSOXhBF7EumrWvmqAAVJSrfGdLaVasgaYK6tkTRDzpZNplh3Tk1aowneXnZffygzIIZ82FWQYBo04IBWwFDOsCawjVbuAfcd9ZslYEYB3QnxV6ogQ4rvXnJ7IHgm3E3SZvt2l45WIyFn6ZKuFifK1aXhZkxHIPf31q68R2idJ764EsfqXfaf3q8H3u4G0NjfWmdPm9nwf/RJDZO+KYFLQ9wXeqRn6u/mRx+u7UD+Uo0xgjRQk1m8V+KuLAmqAosFdlAq0pBO8lEBpSebYdvRWxpM0QSdNrYQcMLVRX7IehizyTt+5sYYbp6f11WWcxLx0QDsUZ/J"
planetary = true
connection {
type = "ssh"
user = "root"
agent = true
host = grid_deployment.d1.vms[0].ygg_ip
provisioner "remote-exec" {
inline = [
"apt update && apt upgrade -y && apt install mc curl git sudo -y",
# "unminimize",
"curl https://raw.githubusercontent.com/freeflowuniverse/crystaltools/development/install.sh > /tmp/install.sh",
"bash /tmp/install.sh",
"source /root/env.sh",
"export PUBSITE=https://github.com/threefoldfoundation/info_threefold_pub/tree/development/wiki_config",
"cd /root && publishtools flatten",
# "curl -fsSL https://code-server.dev/install.sh | sh",
# "sed -i 's/password.*/password: tfrocks/' ~/.config/code-server/config.yaml"
# "apt-get autoremove && apt-get clean"
output "node1_zmachine1_ip" {
value = grid_deployment.d1.vms[0].ip
output "ygg_ip" {
value = grid_deployment.d1.vms[0].ygg_ip
Will try this later today.How do you get updated wiki / web content to display. Is it a manual
