Hello,
So before I installed Zero OS I wiped clean all the storage drives and deleted all the partitions in the windows disk management tool, but I wasn’t sure if this was enough since after installing zero OS I didn’t see any mention of the storage on the screen, so I proceeded with the steps in the guide: installed grml linux distro and then run the command ‘‘for i in /dev/sd*; do parted -s $i mklabel msdos; dd if=/dev/zero of=$i bs=1M ; done’’. for about 3 hours it is just stuck doing it’s thing, and I don’t really know if it does something or not…!
IMG_0611|666x500
I have 4 HHDS total of 20 TB and 1 SSD of 1TB
Or maybe it was enough what I did with the disk management tool ?
pls hlp!
