requirements
- Make it easy for average IT capable person to deploy a hydra node on the TF grid.
- good documentation
- add to github: https://github.com/threefoldfoundation/tfgrid3_tutorials 4
Possibilities
possibility 1:
- Create a weblet that makes it easy to deploy a hydra node on the TFgrid
possibility 2:
- other possibilities?
Extra information
Hydra is an open-source Proof-of-Stake blockchain with a unique set of economic features. It packs a unique combination of inflationary as well as deflationary mechanics as part of its economy that work in parallel and let the real adoption define its total supply.
Everyone can become a full node in a few clicks and stake HYDRA to help maintain the network. Stakers receive a high economic stream through block rewards, awarded by the blockchain. This ensures the chain is always well-protected against ā51% attacksā.
Currently hydra nodes are mostly deployed on AWS and on raspberry Pi.
A docker container was already made:
https://hub.docker.com/r/tmaiaroto/hydra
Here are the files (apologies for not having a repo set up yet) used for the Docker image. https://gist.github.com/tmaiaroto/bea2db0b65cc19e14a635a6fed7b0a41
and the simple k8 deployment.yaml https://gist.github.com/tmaiaroto/1be8885a693482e549a2c6e0e0e624c2
interesting
