Just a very quick note here on people that might still have TFTA’s in their Wallet
There is a description in the library how to convert these back to TFT’s that are needed to proof the minimum balance for an L0 (50k TFT’s ) and an L2 (1M TFT’s).
The description is here.
It is nothing more (and nothing less) than sending TFTA’s to a specific wallet address (in the library document) and this will then send the same amount back in TFT’s to the same wallet. Try it with a small number first to make sure you feel comfortable, after that do bigger batches.
Happy converting!
