How to install VM to default node 3bot?
Not sure I understand the question, the 3Bot runs on a container not a VM. can you explain a bit what you are trying to achieve?
         Based on some other posts, Iām guessing @masteritua means deploying a VM instance on top of the grid. At this time, the only kind of VMs that run on the grid are Kubernetes nodes.
         Yes, the speech is about k8s.
