Hi TFarmers,
The question comes up often on how to delete a 3node or a farm, or change a farm’s name, with polkadot.js instead of the Threefold Portal. This will be included in the FAQ, but here are some Q+A concerning this subject.
Can I change the name of my farm on polkadot.js?
It’s possible to rename farms through the Polkadot UI. For mainnet, use this link: https://polkadot.js.org/apps/?rpc=wss%3A%2F%2Ftfchain.grid.tf#/extrinsics.
Under using the selected account, select the account that owns the farm, choose tfgridModule from the dropdown menu submit the following extrinsic, then select updateFarm(id, name, pricingPolicyId). Then under name: Bytes, write the new farm name. Finally, click on the bottom Submit Transaction at the bottom right of the screen.
How can I delete a farm on polkadot.js?
It’s possible to delete farms through the Polkadot UI. For mainnet, use this link: https://polkadot.js.org/apps/?rpc=wss%3A%2F%2Ftfchain.grid.tf#/extrinsics.
Under using the selected account, select the account that owns the farm, choose tfgridModule from the dropdown menu submit the following extrinsic, then select deleteFarm(id). Then under id: u32, write the ID of the Threefold farm you want to delete. Finally, click on the bottom Submit Transaction at the bottom right of the screen.
I try to delete a node on the TF Portal, but it doesn’t work. Is there any other way to proceed that could work?
It’s possible to delete nodes through the Polkadot UI. For mainnet, use this link: https://polkadot.js.org/apps/?rpc=wss%3A%2F%2Ftfchain.grid.tf#/extrinsics.
Under using the selected account, select the account that owns the farm, choose tfgridModule from the dropdown menu submit the following extrinsic, then select deleteNodeFarm(nodeId). Then under id: u32, write the ID of the 3node you want to delete. Finally, click on the bottom Submit Transaction at the bottom right of the screen.
Thanks!
