for sake of ultimate transparency, we are using a document to high level discuss roadmap see further
updated 2 Aug 2022
for more high level info see: http://roadmap4.threefold.me
internal high level roadmap
A5 (DELIVERED)
- Dedicated nodes
- List in admin panel (reserve, unreserve, see prices) : devnet Tuesday
- See capacity per node, see if pub ip address is possible
- Pricing updates
- done?
- Rest API
- documented?
- GetTFT
- TFConnect 3.5.0
- Cosmos
- TO CHECK
- Is manual up to date !!! https://github.com/threefoldtech/home/issues/1193
A6 has been renamed to 3.6.x
3.6.0 (DELIVERED)
All done:
- Bugfixes
- Deployment add ons (not well documented)
- OwnCloud (centralized deployment tool for farmer, will be done first with greenedge) thabet
- Pokt.network (install < 10 min) (but still hidden how to do it)
- Presearch (documentation) thabet
- Uhuru (install script terraform to run on top of kubernetes with deployment tool) jimber
- TFConnect 3.5.0 (jimber)
- Mattermost, Gitea, Discourse seamless registration/login
- KYC/AML checks & documentation
- TFChain Minimal DAO (rob/dylan)
- for voting for farming changes
- for pricing changes
- to lock farming params in for future farming (to support INCA & our large farmers)
- Specs see Specs for TFGRID DAO
- https://github.com/threefoldtech/tfchain/issues/286
- https://github.com/threefoldtech/home/issues/1228
- Blocking Issues
- Terraform not reliable enough in relation to timeouts (see MMW) (thabet)
- Community member showed how farming can be faked (solution being created), IS THIS DONE?
- We can’t just delete workloads -> pause/resume (azmy/dylan)
- Planetary Network: we make 4 good publ ip addr,
we document, and make sure used everywhere (operations) - Visibility report farming, please add to documentation
- RMB upgrade
- Easy to integrate in website, examples, …
- Have RMB in Rust
- Integrated Encryption
3.6.1
Is a small maintenance release (done before end July)
- some remaining bug fixes
3.7.X
- Minting details (there is forum post about this, please add your comments)
- Panel Staking Support (using stellar)
- Allow people to stake for their validator L2 (specs?)
- Allow people to do delegated staking on Validator from someone else
- Show that validator is giving reward or not (need minimal 2million TFT)
- Max is 3m TFT per validator
- More testing for QSFS
- QSFS not enough tested yet
- need to understand better how to use in Kubernetes, VM, …
- need to check the edge cases & document if changes are required
- example script how to deploy minio on top of QSFS
- ThreeFold Home
- Is to have your own dedicated node on which you can install
- Presearch
- Uhuru (more than 1, using kubernetes)
- TFHUB
- Can be set of scripts e.g. in vlang
- Blocking Issues (make known issues, make sure is on release notes)
- Minting details
- TFConnect
- Private keys management
- CHATBOT framework (new)
- will be used in some of our DAO requirements
- for now more an internal requirement being finished
- POC with Algorand
- get to know what would happen if we start using Algorand
- proof of concept for logic of liquidity pool
3.8.X
specs not finished
TFGrid Admin Portal: major upgrade (SPECS NEEDS MORE WORK)
- More integrated experience for TFGrid Admin Portal
- TFConnect upgrade with additional improvements
- TFT Unvesting (1 week + jimber work, remark only works if TFT price is above 0.1)
3.9.X
specs not finished
- Digital Twin, DEFI WALLET functionality (might also be 4.x)
- GPU first version (only for dedicated nodes) -> DELAY
- In first version, not billing, no farming (just part of dedicated node)
4.X
specs not finished, see the high level overview http://roadmap4.threefold.me
- Minting
- Needs to be done on the sidechain directly (TFChain Substrate), no need for stellar address.
- Farming DAO for TFChain (voting in line with size of farm)
Support for Token Model (specs see here) = WE NEED TO DISCUSS
- WE DO NEED FEEDBACK from crypto community (investors)
- Support switch to Cosmos
- Everyone needs to understand TFChain = sidechain, TFCosmosChain = TFHub 3.0
Postponed
- TFHUB with staking (rob/thabet)
- Minimal DAO (not for TFGrid DAO)
- waiting for cosmos/algorand progress
ON GITHUB YOU CAN FOLLOW ON https://github.com/threefoldtech/home/projects
