I used binance to transfer BTC to Tf connect’s wallet,but its not getting reflected. Seems like I have forgot to add memo. Could u pls help?
Need help with regards to transferring TFT!
Hi there, this would best be addressed with support. You can message them directly via the web chat on our website (threefold.io). It’s the blue icon on the bottom right!
Thanks for your response! I tried messaging directly but didn’t get a reply.
I am trying for 2 days, that the reason y I posted it in the forum.
The team has been alerted and will be looking into this issue tomorrow. Thanks for your patience
I had the same problem and also tried to us sushi swap to get tft . And tried to send btc direct to my threefold wallet it was confirmed sent but doesn’t appear in wallet so don’t try that way ether. The only way that worked for me was with an app called lobster and buying xlm than convert it to TFT than send to your wallet . This app use the stellar network and arrive in your threefold wallet right away
I don’t think there’s a ThreeFold Token pool on SushiSwap. Are you sure it wasn’t another TFT?
The team is working on the BTC deposit issue now.
Glad to hear you were able to get some tokens one way or another
Oh sorry I meant to say pancake swap though smart contract
Thanks for your input!
I have used Solar Wallet to buy and transfer TFT.
It was very easy to setup the wallet and transfer!
