since resolving my issue from issue How do we troubleshoot missing resources (CLOSED) I had to ultimately rewipe my harddrives and when I restarted my node I was assigned a NEW node ID. now my previous node ID is showing as down and when I try to delete it I follow the steps and the request is submitted to the chain but then a response occurs that node deletion failed. who should I advise about this? how should I correct this or do I just ignore it?
Node Deletion Failed (CLOSED)
I had this same issue and asked for help in the Telegram support chat, I’m gonna copy paste the response I got there that helped me:
"If it doesn’t work with the portal, I think you could do it with Polkadot.js UI, going with mainnet this link used to work:
https://polkadot.js.org/apps/?rpc=wss%3A%2F%2Ftfchain.dev.grid.tf%2Fws#/extrinsics
Head to the extrinsics section, select the account that owns the farm, choose tfgridModule from the first drop down, then deleteNode or updateNode.
Not 100% sure it works that way with nodes, but it works to update/delete farms.
But that being said, it doesn’t matter if you have nodes unused that are on the TF Grid. It won’t hinder anything. So you could leave it there."
Hi @amishtech. Good effort in the last 2 stories I read. You are developing these server skills rapidly. For you (and for others I hope) there is a command line tool available that allows you to add/delete/inspect farms and 3nodes on the TFChain.
- https://github.com/threefoldtech/tfchain_client
- https://github.com/threefoldtech/tfchain/tree/development/cli-tool
This provides you with a simple interface to manipulate chain items.
thanks for sharing this by following the steps I was able to get to the point of deletion of the farm node but noticed that in order to send the transaction to be processed there is a fee of Fees of 1.0111 milli TFT will be applied to the submission. I dont have any earned TFT in my account as i am too new and this makes even more sense now why I was getting a error as it may have tried to pull TFT when none was there and errored out and would not delete. I continued to submit the transaction but think I missed a step or did it wrong. under “id: u32” section there was a 0 I replaced the zero with the node ID was trying to delete 3316. I thought that was needed to know which node to delete. but again that did not work again maybe due to not enough balance to pull from but no error was populated so I have no clue
thanks for sharing not sure I understand these links i am not a coder and there is not enough info to guide me on how to use the information in either of the 2 links. any assistance would be nice still learning all of this is like a new language to me but slowly understanding the basics. would love to learn more especially regarding polkadot seems like this is the core.
@amishtech. You are right, there is a cost to deploying on the grid and there is a cost for executing (start/stop) smart contracts. But, contract dissolve when you have no more balance in the wallet, so in the end, everything will self delete.
Hi @amishtech
So just to recap: you can delete a node via the portal.grid.tf, but that being said, the steps given by @proletariat can be more effective. But, it costs some TFT to proceed. All that being said, I want to make it clear that:
it’s OK if you have an unused node ID on your farm.
It doesn’t matter at all. It won’t take resources or anything. So you can simply let it as is, and when you get some TFT you can delete it if you want, it will cost a fraction of a TFT I would say. But it’s not necessary to delete it.
Hope that helps!
I would also stipulate that if deleting a node whether via (http://portal.grid.tf/) or the steps given by @proletariat it will cost 1.0111 milli TFT. the only other issue I see is that the portal.grid.tf should have this same text info presented when trying to delete a node otherwise they would get the error that I received. Technically the error should be changed to “Not enough TFT to process request”
Hi @amishtech
I think you’re suggestion is interesting but I’d like to know what the TF team+devs think about this.
My point is, some people had trouble with the Portal to delete a node, but then it worked with Polkadot.js UI. So maybe it’s not always because there is a lack of TFT fund.
@weynandkuijpers and @scott, what do you think?
Once we get this figured out, we could close the post as it’s been mostly answered.
Hey guys,
So it turned out that the initial link shared was for dev net.
here is the correct link (for main net!):
https://polkadot.js.org/apps/?rpc=wss%3A%2F%2Ftfchain.grid.tf
So for the record, here are the instructions to delete a node or a farm on Polkadot.js / Portal TF Grid:
Can I change the name of my farm on polkadot.js? / How can I delete a farm on polkadot.js?
It’s possible to delete and rename farms through the Polkadot UI. Head to the extrinsics section, select the account that owns the farm, choose tfgridModule from the first drop down, then deleteFarm or updateFarm.
For mainnet use this link.
I try to delete a node on the TF Portal, but it doesn’t work. Is there any other way to proceed that could work?
It’s possible to delete nodes through the Polkadot UI. Head to the extrinsics section, select the account that owns the farm, choose tfgridModule from the first drop down, then deleteNode. For mainnet, use this link.
Since this post has been answered, it will be marked as CLOSED.
Happy Threefolding!
Generally, when using the Portal this should not be a problem because when you activate your account there it is funded with a small amount of TFT. That should be enough to cover the gas fee required to delete a node. I suppose a user could transfer all the TFT out of their wallet and run into an issue… so I tested that case and see this error:
This all seems okay to me. But I’m still wondering about the error you were originally seeing in the portal regarding node deletion failed. Maybe there’s some other issue with the portal?
Yep, my mistake there… thanks for chiming in here and clearing that up
No problem Scott. You definitely helped us a great deal for this issue anyway.
We all should have seen the word DEV in the url!! (tfchain.dev.grid…).
Nothing can stop Threefold and the New Internet!
