Do you have a running node at home and are you located in Belgium and is your ISP Telenet?
We will help you expose your node over IPV6!
1: Find out your public IPV6
If you don’t have JSON parser for your Google Chrome browser install following:
Next, go to https://explorer.grid.tf/explorer/nodes/YOUR_NODE_ID
Scroll down to Ifaces and locate the zos interface, copy the public IPV6 address.
2: Login to your Telenet
Go to https://login.prd.telenet.be/openid/login, if you are logged in go down and select “Your Network” or go to following link: https://mijn.telenet.be/mijntelenet/homenetwork/overview.do?locale=nl
You should see following:
Click on Modem details
You will land on following page:
Next click on Advanced Settings, navigate to IPv6 Firewall & rules.
Next screen should show up:
Copy over the settings on the top and next click on Add Firewall Rule
Copy over the settings from the example except for your IP-address, this should be the one you copied at the start (your node IPV6). Remove the /64 at the end, click Save and then you are done.
Congratulations your node is now exposed over IPV6 on the Threefold Grid!
