Hi,
Since it is not possible to update a VM using Terraform I thought it might be possible to add additional storage to a VM by updating the size of the ZDBs that are underlying the QSFS mounts. I used the terraform configuration from this exampe.
I am probably not aware of how ZDBs work internally but updating the size key in the terraform configuration for the meta and data zdbs did not change the size of the mount in the newly created VM.
Can someone point me in the right direction?
