I’ve managed to setup a farm and I was able to find it on the explorer. Now I would like to setup a presearch node to it. When I try to deploy a new eVDC, i’m unable to find my own farm to use. The dropdown for selecting a farm only has 2 available options and I’m sure there are more farms available than that. Are there additional steps that need to be taken to be able to use my own farm?
Self eVDC Deployment?
Hey @xentt,
Congrats on getting your farm setup
Right now, we have an official Presearch solution on the eVDC which is currently running on testnet. That means that you can only select testnet farms for eVDC deployment.
Running a Presearch node on your own node on mainnet is a bit more involved. I’m working on a guide for this, but need to hammer out some technical issues before I proceed.
Depending on your level of technical experience, you may be able to get a head start by installing a local 3Bot and launching a Kubernetes VM on your farm.
If that all looks like Greek to you (assuming you don’t speak Greek), keep an eye out for a much simpler guide soon. In either case, I’d encourage you to test out the eVDC solution. It’s very slick and only costs a few TFT on testnet.
