Hey all,
This was a tricky one to crack for me and I’ve noticed that others are wondering the same. How to store TFTs on a hardware wallet? If you have a Ledger, you might have noticed that only XLM is supported by Ledger Live. However, you can still use the Stellar app with other wallets to manage TFT.
My experience is with StellarTerm, so that’s what I’ll show here. There are other wallets that offer similar functionality, but I haven’t tested them. Please note that in any case, you’ll need a couple XLM in your wallet to activate it and issue the TFT trustline.
First, navigate to stellarterm.com, and click the login button. Then scroll down and select Ledger or Trezor. For Ledger, open the Stellar app on your device and follow the prompts to log in. I don’t have a Trezor, so you’re on your own there
Next, add a trustline for TFT. You can do that on this page: https://stellarterm.com/account/addTrust/
Now, we’ll find TFT by typing threefold.io into the search box. Like this:
Hit the green accept button to the right of TFT and follow the instructions on your device.
With the trust line enabled, you can now receive TFT at your hardware wallet’s Stellar address. You can send TFT by logging into StellarTerm or another Stellar wallet that supports hardware wallets and using the send feature therein.
And… that’s it! Stay safe, friends.
