Swapping TFT for XLM on Stellar Network (Resolved)
The TFT we receive comes via a token on the Stellar network. However all the steps/instructions for converting TFT to anything else are BSC / Pancake Swap based. If I want to remain within Stellar and avoid Binance chain, how does one do that? I really just want to convert some TFT to XLM. StellarX and stellarterm don’t show TFT in their list of swappable tokens.
Any assistance would be greatly appreciated!
Try StellarTerm, according to coingecko you can do that there.
StellarX nor StellarTerm let me set up a trustline. I was able to finally get it to go with Albedo.link!
Good to know it worked. I’ll give general instructions for stellarx.
How to Swap TFT on StellarX.com
To swap TFT on stellarx.com, you need to have a TFT trust line enabled on your Stellar wallet.
So the easiest way would be to simply add a trust line on stellarterm.com and then go on stellarx.com/swap and then you’ll see TFT in the options.
  1. Add TFT trust line on Stellarterm: in the Farming Guide, read the section Setting up a TFT Trust line on Stellar Blockchain
  2. Swap TFT on stellarx.com/swap
