Hi, I will try to replicate a “down” node in my lab and try to replicated your situation. I’ll also try to reach and other 2 nodes mentioned and see if I can connect.
Just tested the node id’s you mentioned: 3433 works for me:
➜ terraform-dany git:(main) ✗ eval `ssh-agent -s`
Agent pid 313880
➜ terraform-dany git:(main) ✗ ssh-add $HOME/.ssh/mainkey
Identity added: /home/johndoe/.ssh/mainkey (/home/johndoe/.ssh/mainkey)
➜ terraform-dany git:(main) ✗ ping 300:99ac:56a5:41dc:959d:74c8:73fa:ef86
PING 300:99ac:56a5:41dc:959d:74c8:73fa:ef86(300:99ac:56a5:41dc:959d:74c8:73fa:ef86) 56 data bytes
64 bytes from 300:99ac:56a5:41dc:959d:74c8:73fa:ef86: icmp_seq=1 ttl=63 time=346 ms
64 bytes from 300:99ac:56a5:41dc:959d:74c8:73fa:ef86: icmp_seq=2 ttl=63 time=348 ms
64 bytes from 300:99ac:56a5:41dc:959d:74c8:73fa:ef86: icmp_seq=3 ttl=63 time=346 ms
64 bytes from 300:99ac:56a5:41dc:959d:74c8:73fa:ef86: icmp_seq=4 ttl=63 time=347 ms
64 bytes from 300:99ac:56a5:41dc:959d:74c8:73fa:ef86: icmp_seq=5 ttl=63 time=351 ms
^C
--- 300:99ac:56a5:41dc:959d:74c8:73fa:ef86 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4004ms
rtt min/avg/max/mdev = 345.989/347.ssh root@300:99ac:56a5:41dc:959d:74c8:73fa:ef86
➜ terraform-dany git:(main) ✗ ssh root@300:99ac:56a5:41dc:959d:74c8:73fa:ef86
The authenticity of host '300:99ac:56a5:41dc:959d:74c8:73fa:ef86 (300:99ac:56a5:41dc:959d:74c8:73fa:ef86)' can't be established.
ED25519 key fingerprint is SHA256:GZduV+dbPnaRHqRwNzoO1JRVXS5eH+E7ZKeTcfzLrX8.
This host key is known by the following other names/addresses:
~/.ssh/known_hosts:33: 301:d12e:3351:4208:c32b:a725:4b6c:aa03
~/.ssh/known_hosts:35: 301:d12e:3351:4208:9a7c:cf44:d2d4:f788
~/.ssh/known_hosts:36: 301:d12e:3351:4208:6243:5c48:b899:8932
~/.ssh/known_hosts:37: 301:5393:bfab:9bfd:35f:140b:5736:7042
~/.ssh/known_hosts:38: 178.250.167.69
~/.ssh/known_hosts:39: 302:302f:4555:2f55:13f9:5f22:819c:f060
Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
Warning: Permanently added '300:99ac:56a5:41dc:959d:74c8:73fa:ef86' (ED25519) to the list of known hosts.
Welcome to Ubuntu 20.04.4 LTS (GNU/Linux 5.12.9 x86_64)
* Documentation: https://help.ubuntu.com
* Management: https://landscape.canonical.com
* Support: https://ubuntu.com/advantage
This system has been minimized by removing packages and content that are
not required on a system that users do not log into.
To restore this content, you can run the 'unminimize' command.
The programs included with the Ubuntu system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Ubuntu comes with ABSOLUTELY NO WARRANTY, to the extent permitted by
applicable law.
root@proxy1:~#
Since this 3node does not have a public IPv4 address (see explorer: https://explorerv3.grid.tf/nodes) you cannot ask to provision an IPv4 address. Planetary network IP addresses are always available (but for that you have to install the planetary network on your device eg. laptop / desktop).
Same for the other (3033) node:
The authenticity of host '300:be:23eb:3755:549a:afcb:e1ac:f2db (300:be:23eb:3755:549a:afcb:e1ac:f2db)' can't be established.
~/.ssh/known_hosts:40: 300:99ac:56a5:41dc:959d:74c8:73fa:ef86
Warning: Permanently added '300:be:23eb:3755:549a:afcb:e1ac:f2db' (ED25519) to the list of known hosts.
applicable law.
root@proxy1:~#
