TFGrid roadmap TFGrid 3.7.x
updated 2 Aug 2022
for more high level info see: http://roadmap4.threefold.me
3.5-3.6 (DONE)
see Internal roadmap 3.5, 3.6, 3.X . .
- Dedicated nodes
- New refreshed more easy UI
- Pricing updates
- Rest API
- GetTFT
- TFConnect 3.5.0
3.7.X (needs to be reviewed)
- Minting details (there is forum post about this, please add your comments)
- NEED MORE INFO HERE (LEE/THABET?)
- Panel Staking Support (using stellar)
- Allow people to stake for their validator L2 (specs?)
- Allow people to do delegated staking on Validator from someone else
- Show that validator is giving reward or not (need minimal 2million TFT)
- Max is 3m TFT per validator
- Production release of QSFS = Quantum Safe FileSystem
- QSFS can use some more testing
- need to understand better how to use in Kubernetes, VM, …
- need to check the edge cases & document if changes are required
- example script how to deploy Minio on top of QSFS
- ThreeFold Home
- Is to have your own dedicated node on which you can install
- Algorand development chain
- Pre-search node (internet search)
- Pokt.network
- Kubernetes Cluster
- FreeFlow/Uhuru = our first digital twin implementation, host digital life for your friends and family
- Can be set of scripts e.g. in vlang, worst case, but would prefer web UI or wizards
- Blocking Issues (make known issues, make sure is on release notes)
- Minting details
- TFConnect
- Private keys management
- CHATBOT framework (new)
- will be used in some of our DAO requirements
- for now more an internal requirement being finished
- POC with Algorand
- get to know what would happen if we start using Algorand
- proof of concept for logic of liquidity pool
- TFGrid Solutions Concept
- allow any solution provider to get income by developing solutions on top of TFGrid
- Reservations of validators L2 and L1 on Stellar or Algorand (TBD)
3.8.X
specs not finished
- IPFS support on quantum safe storage system
TFGrid Admin Portal: major upgrade (SPECS NEEDS MORE WORK)
- More integrated experience for TFGrid Admin Portal
- TFConnect upgrade with additional improvements
- TFT Unvesting (1 week + jimber work, remark only works if TFT price is above 0.1)
3.9.X
specs not finished
- Digital Twin, DEFI WALLET functionality (might also be 4.x)
- GPU first version (only for dedicated nodes) -> DELAY
- In first version, not billing, no farming (just part of dedicated node)
4.X
specs not finished, see the high level overview http://roadmap4.threefold.me
- Minting
- Needs to be done on the sidechain directly (TFChain Substrate), no need for stellar address.
- Farming DAO for TFChain (voting in line with size of farm)
Support for Token Model (specs see here) = WE NEED TO DISCUSS
- WE DO NEED FEEDBACK from crypto community (investors)
- Support switch to Cosmos
- Everyone needs to understand TFChain = sidechain, TFCosmosChain = TFHub 3.0
Postponed
- TFHUB with staking (rob/thabet)
- Minimal DAO (not for TFGrid DAO)
- waiting for cosmos/algorand progress
ON GITHUB YOU CAN FOLLOW ON https://github.com/threefoldtech/home/projects
