Hello all,
We are happy to announce our playground for TFGrid3 weblets.
- Weblets are compiled javascript widgets which use the ThreeFold GRID Javascript client.
- Weblets can be embedded in any website or blog, each weblet is 100% decentralized.
- Weblets make it easy to reserve capacity.
The playground is a graphical user interface which hosts the weblets. You can use it to deploy solutions on the TF Grid 3. Amongst others, you can deploy VMs, Kubernetes, Caprover…
Caprover is a very cool tool to deploy in an easy way much more complicated solutions, check it out.
The tool is available here.
Remark: first you need to define an identity on the TFChain using the portal and then import the mnemonics (which are only visible in your local machine) into a profile you create on the playground, see manual linked below.
More info can be found in the TF Grid 3 wiki manual
Please join us and help with the testing !
