Wifi on TFT Node
Hi All,
Wondering if/how it’s possible to setup ZeroOS to run using the wifi chip on my PC.
I remember when first setting it up it said something about scanning for wireless networks, but I’m not sure about that. (For reference, I’m using an IBM Thincentre M900 Tiny).
[As a side question, assuming performance/earnings would suffer due to wifi/vs ethernet, by how much might it suffer- ? Node(s) would be right near wifi router].
I think Zero-OS needs an ethernet cable to function properly. I don’t think WIFI is possible.
Let’s see if someone can say otherwise.
Good question.
thanks… @weynandkuijpers any thoughts?
Wifi is not supported by Zero OS. There are a number of issues, like reliability, performance, configuration requirements, and driver support that make this a no go.
Understood, thank you sir!
Sure thing, and happy farming!
