Hi guys,
That is how my disks look like:
Disk /dev/nvme0n1: 477 GiB, 512110190592 bytes, 1000215216 sectors
Disk model: SAMSUNG MZVLB512HBJQ-00000
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xb213dd28
Disk /dev/nvme1n1: 477 GiB, 512110190592 bytes, 1000215216 sectors
Disklabel type: dos
Disk identifier: 0xcb3975c3
Disk /dev/sda: 14.2 GiB, 15289286656 bytes, 29861888 sectors
Disk model: Transcend 16GB
Disklabel type: dos
Disk identifier: 0x86c520af
Device Boot Start End Sectors Size Id Type
/dev/sda1 1 4095 4095 2M e W95 FAT16 (LBA)
Where sda is the USB stick with ZeroOS image attached (I booted from the network drive to get this information).
I have chosen to boot from the UEFI USB from the boot menu, the image of the latest ZeroOS was successfully downloaded. Started, and the node was detected by the 3Bot. But no resources were detected on the node and there is an indicator of the bad network configuration. I am pretty sure that the server has both a public IPv4 address and IPv6 subnet.
Could you help me to detect the reason for such behaviour?
P.S. I am experimenting on the small node but going to add several much more powerful nodes once I am succeeded with the installation of this node.
P.S.2
Hardware data:
CPU1: AMD Ryzen 5 3600 6-Core Processor (Cores 12)
Memory: 64255 MB
Disk /dev/nvme0n1: 512 GB (=> 476 GiB)
Disk /dev/nvme1n1: 512 GB (=> 476 GiB)
Disk /dev/sda: 15 GB (=> 14 GiB)
Total capacity 968 GiB with 3 Disks
Network data:
eth0 LINK: yes
MAC: a8:a1:59:4d:2c:27
IP: 135.181.214.169
IPv6: 2a01:4f9:3a:2c96::2/64
IntelĀ® Gigabit Ethernet Network Driver
